Activity Forums DSLR Video Zoom H4n Limiting Problem (?)
  • Zoom H4n Limiting Problem (?)
    Posted by Kevin Eugene on June 21, 2014 at 7:08 pm
    I looked for an appropriate forum, and it looks like these questions are posted here – apologies if this is not the correct place for this question – I couldn’t find a “Zoom” or a “Sound” forum.
    I have a Rode NTG-3 running direct via XLR into channel 1 of the Zoom H4n. The recording shows up on both channels (which is what I want). The Zoom is set to use 48+ phantom power. I am using the AC Adapter on the Zoom.
    I have no problems with the quality. I was seeing if I could record decent sound at a higher input level to something like -3DB without distortion.
    As I increased the Zoom input level, 30, 40, 50, 60, 70, and so on, I noticed the input level meter on the front of the Zoom was pegged at-6DB. I brought this into Audition and sure enough, the sound is pegged to -6db no matter what the input level is. I checked the H4n settings and everything obvious on the Zoom is off – limiters off, compression off, etc, etc.
    Is this normal behavior for the Zoom H4n?
    I feel like I am missing something obvious here.
    Thank you in advance for your answer.
    My Best,
    Kevin – not a sound guy. 🙂
    Tim Neighbors replied 12 years, 2 months ago 3 Members · 3 Replies
