Activity Forums Audio zoom h4n external audio
  • zoom h4n external audio
    Posted by Lawrence Chan on May 30, 2014 at 2:31 am
    Hi, I just purchased some lav mics from Amazon and they don’t work on the H4n. I tried phantom power and even connected the 3.5 mm jack to the xlr input. The mic works fine with camera input, but all I hear is static on the zoom. Thanks!
    Michael Paul replied 12 years, 3 months ago 2 Members · 4 Replies
  • Michael Paul
    May 30, 2014 at 3:51 pm
    If your lav mic has a 3.5mm connector on the end, then connect it to the “Ext Mic” jack on the back of the H4n right above the speaker. Go into the Menu, select “Input” and find “Plug-in”. Set that to “On”.
    Select the “Mic” input button on the front panel and it should work
    Michael Paul
    Location Sound Corp
  • Lawrence Chan
    May 31, 2014 at 2:38 am
    Thanks a whole bunch! It’s going really well now. Thanks again!
  • Lawrence Chan
    May 31, 2014 at 3:18 am
    Is there any way to do this through the XLR input on the bottom? The placement is much more convenient.
  • Michael Paul
    June 4, 2014 at 3:17 pm
    Not with the lav mic you have. Your mic need +5V “Plug-In” power, and the XLR’s only provide +48V, which is too much. If you had a lav mic with a barrel power supply on the end (with an XLR connector), then you could do it, but yours is terminated to plug directly into a wireless transmitter or a mini-jack
    Michael Paul
    Location Sound Corp
