Activity › Forums › Adobe Premiere Pro › Zoom H4N as audio interface for Voice Overs
  • Zoom H4N as audio interface for Voice Overs
    Posted by Andrew Sheppard on January 26, 2013 at 7:14 pm
    Hey guys,
    First time posting on this forum which is exciting because I’ve solved a lot of issues in the past thanks to this community so a big thank you first off.
    Now I do have a question and it is probably a simple solution but I can not for the life of me figure it out. So I’m using a Zoom H4N as an interface in Premier CS6 to record some VO. I don’t usually do this but it’s a low budget thing so I’m stuck with no sound tech. Any ways I have a Sennheiser ME66 (I know don’t ask) that I’m using to capture the audio and I have everything set up properly in CS6 where it’s recording to the time line but the audio is just completely blown out and even though its leveled on the recorder it keeps coming in extremely hot. Is there a way to adjust the input so it’s not so hot. Probably a dumb question but I can not for the life of me figure it out.
    Dan Mcdermott replied 10 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Angelo Lorenzo
    January 26, 2013 at 8:06 pm
    I answered this exact question a few weeks ago: https://forums.creativecow.net/thread/3/934503
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Andrew Sheppard
    January 26, 2013 at 11:02 pm
    Thank you so much. I did change the input into windows. It’s now at 4 out of 100 so I think I really need a pre amp at some point. Does the Zoom not act as a pre amp itself? Is there any point adjusting the input on the H4N itself?
    Thanks again for the reply
  • Angelo Lorenzo
    January 27, 2013 at 12:47 am
    All a preamp does is raise mic or instrument level to line level. The zoom has an integrated preamp but it should also take a line level from the 1/4″. I don’t particularly like using the phantom power off the Zoom so that’s a situation where I’d use a preamp.
    Regardless, a preamp fixes the signal too low problem when you have a signal too high problem.
    Here is what I would do: Play some static into your microphone. From the radio or whatever as long as it’s a solid constant volume. Look at the H4N and adjust the input until it hits -12db (arbitrary, you’ll see why in a second). In your sound recording program on Windows, watch your input levels and adjust Windows recording level until it matches what the zoom says. At this point Windows and the H4N are at unity, Windows isn’t adding any gain to the signal.
    From there, just concentrate on adjusting the input level on the H4N as you need for each particular person’s voice level.
    Angelo Lorenzo
  • Andrew Sheppard
    January 27, 2013 at 1:03 am
    Thanks for the advice. Did this and my levels in windows had to be dropped to 4. Not sure if that is normal but 4/100 in terms of input seems to give me a good level. Thanks for the advise. Now however I’m finding more problems. Will start a new thread I guess.
  • Ivan Myles
    January 27, 2013 at 5:13 am
    To expand on Angelo’s linked post, try troubleshooting each component to identify the root cause:
    Zoom H4N:
    – What are the settings for mic level, frequency/bit-depth, Phantom, Comp/Limit, Level Auto, and MS Matrix?
    – Which input lights are on (MIC, 1/2, or all)?
    – How does a sample sound if you record to an internal SD card?
    – Do the clip meter lights come on during recording?
    Cable:
    – Assuming you are using a USB cable, have you tried capturing a sample with an analog Line Out cable?
    Windows Audio:
    – In Windows, open Recording Devices > Properties > Advanced to check the settings: typically 16-bit and 44100Hz or 48000Hz; enable both items under Exclusive Mode.
    – Is the Recording Devices > Properties > Levels tab what you used to set volume to 4? If not, what is the setting? Is there also a Microphone Boost setting? For the time being, set the microphone level to around 60-80 and, if applicable, set boost to 0.0 dB.
    Audio Card Software:
    – Look in Windows Control Panel and the Start folder to see if there is a software application for the computer’s audio card. If so, open it and check the settings.
    Audio Capture Software:
    – Use a few different types of software to capture audio: Premiere Pro, Windows Sound Recorder, other (QuickTime, Adobe Audition/Soundbooth, etc). Before recording, check settings in the software for frequency, bit depth, volume/gain/trim, etc. Capture a few samples and compare recordings to audio recorded on the Zoom memory card:
    1) Zoom internal mic recorded to Zoom SD card
    2) Sennheiser mic recorded to Zoom SD card
    3) Sennheiser mic, USB cable, Windows Sound Recorder
    4) Zoom internal mic, USB cable, Windows Sound Recorder
    5) Zoom internal mic, USB cable, Premiere Pro
    6) Sennheiser mic, USB cable, Premiere Pro
    7) Sennhieser mic, USB cable, Audition/Soundbooth/QuickTime/other
    8) Zoom internal mic, USB cable, Audition/Soundbooth/QuickTime/other
    If the issue still exists, take a few samples using an analog Line Out cable to see if it makes any difference.
  • Campbell Wilson
    August 16, 2013 at 2:07 am
    I’m having trouble getting audio into PP CC with my H4n.
    I’m on Mac and have the I/O working and PP CC is seeing the H4 in audio hardware, but I’m not able to get it to my timeline
    all suggestions welcome.
  • Dan Mcdermott
    May 5, 2016 at 11:13 pm
    I had this exact problem in Windows 7 64 bit. The issue was the Windows generic driver. It read the H4n as a microphone and there was no way to switch it and have Windows see it was line level. The solution is to download the driver from Zoom and it will show up and work fine.
    https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h4n-handy-recorder#downloads
