Activity › Forums › DSLR Video › Zoom h4n and Canon 7D
  • Zoom h4n and Canon 7D
    Posted by Nick Karner on September 29, 2012 at 8:17 pm
    Hi. I record the audio separately into my zoom and then use plural eyes to sync it up in adobe premiere for editing. I believe my settings are at 48/24bit on the zoom as wav files. I feel like the audio is VERY slightly off. It’s hard to tell, but has it been proven whether or not you have to adjust one or the other to sync them properly?
    Brent Dunn replied 13 years, 11 months ago 4 Members · 3 Replies
  • Steve Crow
    September 29, 2012 at 9:29 pm
    Sometimes you can have sync issues when previewing video in the timeline of your NLE but once you export it then things are fine, so do that check first. I assume that Premiere does the same thing as Final Cut Pro in that once you bring the audio into your timeline it is transcoded to match whatever your sequence settings are (that’s a FC term, may be different in Premiere, probably is in fact) so I don’t know why you are experiencing audio drift.
    Steve Crow
    Crow Digital Media
    http://www.CrowDigitalMedia.com
  • Phil Balsdon
    October 3, 2012 at 11:45 am
    I record my master audio on a Tascam DR100 and feed a line output to the 7D via a Beachtek DXA SLR. I found doing this the audio recorded on the camera was consistently 2 frames behind video. I attributed this to delay from Tascam output to Beachtek as recording with the mic directly into the camera didn’t do this.
    I just shift all audio, after PluralEyes 2 frames.
    You can check this by recording a slate and seeing if the clap vision and audio link up. (Doesn’t have to be a slate, just anything you can clearly see hear a clap and see the vision that caused it).
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://philming.com.au
    https://www.steadi-onfilms.com.au/
  • Brent Dunn
    October 9, 2012 at 5:56 pm
    Plural eyes is not perfect. Sometimes it works, sometimes you have to tweak the sync, but at lease it gets it close enough and saves you time scrubbing through long audio files.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
