Activity › Forums › DSLR Video › Zoom H4-N vs. Tascam DR-40
  • Zoom H4-N vs. Tascam DR-40
    Posted by Pete Burger on May 14, 2012 at 7:55 am
    Does anyone has some first-hand experience with those two mobile recorders?
    I worked with the Zoom before and was quite pleased with the quality.
    What I’m most interested in, is the difference concerning recording with external microphones and grabbing audio signals from a mixer. So the internal mics are of lesser concern for me.
    Thank you in advance! Any opinion much appreciated!
    “Tragedy is a close-up; comedy, a long shot.” – Buster Keaton
    Me on Twitter (english/german)
    https://twitter.com/FastFoodVideo
    My german blog
    https://fastfoodvideo.de
    Pete Burger replied 14 years, 2 months ago 6 Members · 14 Replies
  • 14 Replies
  • Anders Larsen
    May 14, 2012 at 8:27 am
    Hi Peter
    I have no first hand experience, but Nofilmschool.com has a pretty extensive comparison article that might be of intrest to you:
    https://nofilmschool.com/2012/04/audio-recorder-roundup-h4n-zoom-vs-tascam/
  • Pete Burger
    May 14, 2012 at 8:32 am
    Thank you, Anders!
    A comparison like that, was exactly what I was looking for. Much appreciated!
    My german blog
  • Anders Larsen
    May 14, 2012 at 2:49 pm
    You’re welcome. Happy to help.
  • Declan Smith
    May 14, 2012 at 3:45 pm
    I recently was in the same position, however I am interested in quality of the microphones. I decided to spend a bit more and go for the Roland R26, on spec, but mainly because it can record 6 channels, and has nice big level controls. I received it last week and it’s the first product I’ve bought in a long time that excites me more now I have it. It’s simple awesome. Rigged feeling, easy to use and absolutely crystal clear sounds. I have yet to plug an external mic in though!
    Declan Smith
    https://www.madpanic.tv
    After Effects CS5.5/ FCS3 / Canon 7D / Canon XL2 / Reason / Cubase
    “it’s either binary or it’s not”
  • Pete Burger
    May 14, 2012 at 9:46 pm
    Thank you Declan!
    Really interesting product. Well, I think I’ll have to ponder if it fits my budget…
    My german blog
  • Paul Kagawa
    May 21, 2012 at 3:34 am
    I’ve used both and like some things about the Tascam, especially the the line/mic switch, the locking XLRs, and light weight. One problem with the Zoom is that the mic inputs are very sensitive, and I’ve had several occasions where the audio from a mixing board distorted because I couldn’t lower the input enough. I thought the Tascam would be a good solution because it has a mic/line input switch to attenuate the signal.
    But I ran into a separate problem with sync drift on the Tascam after an hour of recording. You can see the details here: https://wp.me/p2gorK-1I
    So I still use the Zoom, but run the signal through a Shure portable mixer first so I can get a real mic level output to the Zoom.
    Hope that helps
    –Paul Kagawa
    Website: http://www.paulkagawa.com
    Blog: http://www.paulkagawa.com/blog
    twitter: @paulkagawa
  • Pete Burger
    May 21, 2012 at 11:10 am
    Thank you, Paul!
    Very valuable information! Thank you for posting! Had to shoot some band-concerts and theater performances in the past and was planning for future jobs to get audio directly from the mixer into the recorder instead of the cam and do syncing in post… So, maybe it won’t work as perfectly as I hoped for with the Tascam… bought it last week…
    But most of the time (99% of my jobs), I’ll be using the recorder as an external audio device with my DSLR or Sony HD cam for shorter videos, interviews and stuff… So I’ll have clips no longer than max. 4-5 minutes.
    As you wrote, the line/mic switch is a blessing and the locking XLRs are extremely important for me when in the field.
    Sound quality (from what I tested so far) is very good – very low noise for a recorder of that price.
    So, thanks again! Much appreciated!
    My german blog
  • Paul Kagawa
    May 21, 2012 at 3:15 pm
    Peter, for short runs the Tascam should be fine.
    The other issue I had with it was a write fail to an SD card. I had set it up to write a new file every 1gb automatically, but the first time it tried to save the file it said something like “Write Error – Press Enter.” When I checked later there was a file name but no data, so I lost about an hour of the recording. (Details here: https://wp.me/p2gorK-17)
    After that fiasco I would use a card that is certified by Tascam, and test it a lot. You can get a pdf of their Tested Media List here: https://tascam.com/product/dr-40/downloads/
    I now routinely use XLR Y-cables and simultaneously record to the camera as a backup, even with the Zoom H4n.
    Best of luck with your projects.
    –Paul Kagawa
  • Pete Burger
    May 21, 2012 at 8:55 pm
    Paul, I already saw the article on your blog and bookmarked it for later reading.
    By the way, your blog is a great resource!
    The XLR-Y cable advice is an excellent tipp! I wouldn’t have thought about that.
    And with the two XLR-inputs of my Sony I’ll get even two “backups” – one directly from the Tascam, the other from the on-camera mic (which I use sometimes for ambience).
    Again, very much appreciated! Thank you!
    All the best to you and your projects!
    Greetings from Munich, Germany!
    My german blog
  • Brent Dunn
    May 23, 2012 at 5:32 pm
    Peter:
    Roland has a much better recorder system than both of these. Roland has great preamps, which is what you really want in a recorder.
    https://www.bhphotovideo.com/c/search?atclk=Brand_Roland&ci=14934&N=4248627700+4291256676
    R-16 being around $500
    R-5
    Roland R-44 has great preamps, the best of these…but $1,000
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
