Activity › Forums › Adobe After Effects › Zoom Effect ?—student in trouble!!
  • Zoom Effect ?—student in trouble!!
    Posted by Rodrigo Escobedo on October 7, 2016 at 2:04 am
    Hello, I am a student with intermediate knowledge of after effects, I tried to get this EFFECT of transsicion between photographs but I do not like the end result.
    How can I make this EFFECT? help!!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Daniel Waldron replied 9 years, 11 months ago 5 Members · 5 Replies
  • Tudor “ted” jelescu
    October 7, 2016 at 7:00 am
    The example you provided is not just a simple effect of transition between photographs.
    There is a lot of planning and production that went into this ad.
    Each “photograph” is actually a series of photographs taken from the same spot with a zoom lens in small increments (from wide to narrow) or possibly with a camera on a dolly that is moved on a track keeping the same location of the vanishing point. All the shots are then composited with a morph transition to simulate the travel/zoom through one shot. Each shot is carefully staged to provide a transition point for the next shot and the zoom/travel happens at constant speed.
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
  • Mikael Björnson
    This video gives you the basic principles of zooming between stills. Hope it helps:
    https://www.youtube.com/watch?v=zCFF9emjYFc
  • Mikael Björnson
    October 7, 2016 at 7:53 am
    Sorry, I pasted the wrong link above. Unless you know italian, of course.
    https://www.youtube.com/watch?v=2GAMk9cI45U
    But that video only shows how you zoom between pictures from Google Earth. They have the very thing you’re looking for: identical vantage points and variable zoom of the same motif. If you want the effect to be as perfect and fluent as the video you pasted, then yes: you will have to shoot the pictures with the end result in mind as described above. Consider the perspective lines of the photographs in the video. They all align. This is the key to beautiful zoom endless zoom effects.
  • Roei Tzoref
    October 7, 2016 at 12:50 pm
    [Mikael Björnson] “But that video only shows how you zoom between pictures from Google Earth. “
    probably better to learn from the original tutorial: https://www.videocopilot.net/tutorials/earth_zoom/
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Daniel Waldron
    October 7, 2016 at 1:41 pm
    You can do a somewhat limited version of that by utilizing 3D Vanishing Point.
