Activity › Forums › Apple Final Cut Pro Legacy › Zoom and Pan and re-render
  • Zoom and Pan and re-render
    Posted by Lawrence Eaton on May 29, 2009 at 2:48 pm
    My work requires an obscene amount of zooming and panning and while I can deal with this, satisfactorily, I’m wondering is there a way around having to re-render every single time, I make one change to a clip?
    Many thanks,
    Lawrence Eaton
    John Fishback replied 17 years, 4 months ago 2 Members · 1 Reply
  • John Fishback
    May 29, 2009 at 3:48 pm
    Having to re-render is mostly a function of the power of your edit computer (and the codec you edit with). I can move images around in DVCProHD and get a green line, so I can play without re-rendering. You don’t mention what codec you’re using. If you were editing in 8-bit UC and switched to DVCPro50 you might not have to render as much.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
