Activity › Forums › Adobe After Effects › Zomming in on video clip
  • Zomming in on video clip
    Posted by Ryan Sereno on October 27, 2011 at 5:59 pm
    I have a 1080p video clip that I want to add a slight zoom in effect to give the illusion of the camera dollying in.
    I don’t want to zoom in on the clip so that the resolution goes under 720p
    I tried animating the scale of the clip, but it seems like it’s losing too much resolution, even though I’m only making it 20% bigger. To be 720 it would have to be around 44% bigger. But I don’t need it that big, I’m happy with the 20% size increase but not the loss of resolution.
    I think the problem might be because the clip is being stretched to 1080, instead of the actual composition shrinking to 720.
    Is there any way to animate the composition size?
    Alberto Fernandez replied 14 years, 9 months ago 5 Members · 5 Replies
  • Roland R. kahlenberg
    October 27, 2011 at 6:28 pm
    Have you tried using AE’s camera? Camera Mapping/Projection is another option although my thoughts are that a basic camera move should do the trick.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Todd Kopriva
    October 27, 2011 at 7:06 pm
    Scaling up by that much will cause a loss of quality, no matter how you do it. You are forcing the software to make up (interpolate) new information to put in between the pixels of the original image.
    Premiere Pro has higher-quality scaling algorithms than After Effects, so you might want to take your clip over to Premiere Pro just for upscaling. See this page for details about scaling in Premiere Pro.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Ryan Sereno
    October 27, 2011 at 7:34 pm
    Okay, I understand that scaling up will cause a loss in quality, but my question is, can I animate the composition resolution? That way the clip isn’t changing size, but the composition window is just shrinking down
  • Gary Hazen
    October 27, 2011 at 7:51 pm
    [Ryan Sereno] ” can I animate the composition resolution?”
    No.
    What’s your final output? DVD? HD File?
    If your final output is for DVD you could set your comp at a standard def resolution(ex: D1 widescreen). You would have plenty of room for zooming in on the high res footage without losing quality.
  • Alberto Fernandez
    December 16, 2011 at 4:25 pm
    Yes you can Do it, check this out..!
    This was done with Adobe After Effect CS4.
    https://youtu.be/E2kdB0uWxAY
    Regards;
