Activity Forums Apple Final Cut Pro Legacy zero duration white files
  • zero duration white files
    Posted by Robbie Allen on February 9, 2007 at 4:37 pm
    I’m capturing footage that was offline in an Avid – moved to my FCP via Automatic duck, thence to another FCP. Some of the footage is coiming in fine, some less so:
    batch capture goes through all the motions – running the tape, claiming to capture. Then, however, the clip still comes up as ‘media offline’. Reconnecting the media does the same – goes through the process all the way up to finding the media, but will not allow me to ‘connect’ – the button stays grayed out.
    Looking at the quicktime files created gives me a clue: although they’re full-size NTSC DV (ie 6s = about 22mb), they have a duration of 0, and are white.
    All the media for this project is NTSC DV, so why it works for some tapes and not others is a mystery. Prefs have been trashed, offending tapes have deen test-captured with different in and out points no problem.
    Any ideas?
    Robbie Allen replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
