Activity Forums Zaxwerks Zaxwerks/AE render issues
  • Zaxwerks/AE render issues
    Posted by Brian Lynn on August 10, 2008 at 11:54 am
    My Zaxwerks/AE combo will NOT render properly.
    No matter what I do, Zaxwerks renders every other frame OR LESS completely blank. I have tried rendering layers separate, render a portion of the layer only, all kinds of things.
    Yesterday my problem was every other frame renders properly, today its every third frame renders properly. And by properly I mean they actually have SOMETHING in them! The rest of the frames in between are completely blank!
    Its only happening to one layer, and of course its the most important one… I’ve sort of faked it through for now using just a single correct frame as a still image, but the dynamics of the lights playing on the text is completely lost.
    This is driving me insane. I tried the After Effects forums already and discovered this forum through Zaxwerks website or I would have posted here first. I went to AE forum because I am using the plugin…
    Brian
    Matt Rhodes replied 18 years ago 2 Members · 1 Reply
  • Matt Rhodes
    August 19, 2008 at 4:56 pm
    Hello Brian.
    Would you be able to send me your project?
    You can usually just send me the .aep file,
    but other media files may help.
    Send files to: matt@zaxwerks.com
    Be sure to send along a few instructions for
    me to follow so that I can see what you’re seeing.
    Thanks a lot.
    Matt Rhodes
    Zaxwerks, Inc.
