Activity Forums Zaxwerks zaxwerks proanimator presets
  • zaxwerks proanimator presets
    Posted by Aqeel Sami on May 11, 2012 at 7:45 pm
    I used to install zaxcwerks proanimator without problems but last time i formated my pc i noticed that there are no presets and when i tried to load them into script folder of after effects cs55 they didn’t show when i load the filter. is there a solution for this problem.
    Zax Dow replied 14 years, 4 months ago 2 Members · 3 Replies
  • Zax Dow
    May 11, 2012 at 10:45 pm
    Open ProAnimator, then open the Preferences and click the Restore To Factory Presets button, then Exit and relaunch ProAnimator.
    If this doesn’t fix it take a look at this FAQ from the Zaxwerks Help Center: https://zaxwerks.com/helpcenter/faq7.shtml
    It tells you how to reset the factory presets
  • Aqeel Sami
    May 12, 2012 at 10:56 am
    when i installed the software to a folder in desktop i found that standalone proanimator doesn’t installed although i checked it to be installed and presets folder is empty and some other folders….does that help to solve the problem.
  • Zax Dow
    May 15, 2012 at 7:55 pm
    Are you trying to run the installer from inside of a ZIP file?
    You must unzip the zip file before trying to run the installer.
