Activity › Forums › Zaxwerks › Zaxwerks 3D Invigorator AE plugin not importing .ai log
  • Zaxwerks 3D Invigorator AE plugin not importing .ai log
    Posted by John Drach on July 5, 2007 at 8:30 pm
    I really need some help, I am on a project deadline.
    I am using AE 7, Illustrator CS3, and Zaxwerks 3D Invigorator AE plugin.
    I can not import a basic .ai file into my Zaxwerks 3D Invigorator software. When I import I get a message that reads, “There were no usable vector paths in this file.”
    Does anyone have this problem? I have already tried saving my .ai file as CS1 an CS2. Still no good.
    Please help!
    John.
    JOHN D.
    John Drach replied 19 years, 2 months ago 3 Members · 6 Replies
  • Serge Hamad
    July 5, 2007 at 10:23 pm
    Make sure that the “use Compression” box is not checked when saving your file.
    let us know if this doesn’t help. You could then send me your file here: serge_01 (at) (msn) (dot) (com)
    Salut.
    Serge
    INVIGORATOR-TRAINING VOL.1 soon available here: https://www.nyc-visual.com
  • John Drach
    July 6, 2007 at 1:22 am
    At the moment my logo is just a circle I made in Illustrator to see if I can extrude. I can’t even do that. I still get the same error message. I can use all the other functions but importing an illustrator file just wont work.
    JOHN D.
  • Serge Hamad
    July 6, 2007 at 2:38 am
    Did you do what I already suggested?
    Did you give a fill color to your object in IL or at least a stroke?
    Without seeing your file I can’t really say what you did wrong.
    Salut.
    Serge
  • John Drach
    July 6, 2007 at 2:53 am
    It’s just a circle with a stroke. I think it’s my software. Because if I have just a circle with a stroke and I can’t import that then there is something wrong.
    JOHN D.
  • Jon Okerstrom
    July 6, 2007 at 3:35 am
    John,
    Which version number of Invigorator are you using?
    Jon
  • John Drach
    July 6, 2007 at 10:50 am
    I’m running AE7 on a G4 powerbook with Zaxwerks 3D Invigorator Pro 4.09.
    I did a test where I saved down to every version of Illustrator on my computer and I can only seem to open a illustrator file if it is saved to version 10 even with all check boxes unchecked in the save dialog box
    (I left .pdf checked)
    So problem is solved, now I just have to figure out how to use that function 🙂
    Thanks for the help and the super quick response.
    John.
