Activity Forums Zaxwerks Zaxwerks 3D Flag HighResolution Export Error in AE
  • Zaxwerks 3D Flag HighResolution Export Error in AE
    Posted by Pratik Raj on May 22, 2020 at 12:34 am
    Hello Everyone,
    I’m using Zaxwerks 3D Flag to create a cloth sim Background which will become a Panning Background of a 1920×1080 video.
    But I’m not able to export a High Res video of dimension 5760×1080 in After Effects. The Exported file is all blurry.
    Please Help!
    Pratik Raj replied 6 years, 3 months ago 2 Members · 2 Replies
  • Zax Dow
    May 28, 2020 at 6:55 am
    Hi Pratik,
    It looks like the comp or layer you are using for your flag’s color map isn’t high resolution enough. If you are exporting at 5760×1080 then your comp should be 5760×1080 and the layer you have 3D Flag applied to should also be 5760×1080. Also, the map you are applying to the flag should also be at least 5760×1080.
    It’s best not to apply the Flag plug-in to the layer that is the color map. The plug-in should be applied to a solid that is Comp size.
    If it still looks blurry, send your project file to support (at) zaxwerks.com. When using the OpenGL renderer there is a max map size inside the materials editor that can down-res your maps and might need to be increased.
    -Zax
  • Pratik Raj
    May 29, 2020 at 7:15 pm
    Thanks a lot, Zax.
    I’ll try working according to your suggestion and update you if that works for my project.
    Thanks again! 🙂
