Activity › Forums › Canon Cameras › Zacuto z-finder mounted on Canon 5D mkII
  • Zacuto z-finder mounted on Canon 5D mkII
    Posted by Steve Ralston on September 15, 2010 at 1:50 pm
    Hi all,
    I”ve just bought a Zacuto z-finder for my Canon 5DmkII. Although I haven’t fitted it yet I’m confused as to how I will attach the camera to a tripod as the base plate for the Zacuto screws into the hole for the tripod. Am I missing something obvious here? It has to said I often do!
    Richard Van den boogaard replied 16 years ago 2 Members · 6 Replies
  • Richard Van den boogaard
    September 15, 2010 at 2:39 pm
    Depends on which version of the Z-Finder you have. I have V2’s and they connect on the back with a glue-on frame, so there is no baseplate. The new V3s do have such a Gorilla Baseplate. This is supposedly handier when you have a Zacuto rig, since you can directly attach the 15mm rods to it, but that leaves the tripod/monopod mounts…
    I have Manfrotto 394 quick release plates all over the place, so I can quickly switch from one to another. Speed is what counts when you’re shooting and this works for me.
    Richard van den Boogaard
    cameraman / editor / video marketing consultant
    Branded Channels
    W: http://www.brandedchannels.com
  • Steve Ralston
    September 16, 2010 at 9:46 am
    Thanks for the reply Richard.
    Basically then I’m screwed!! I don’t really understand why they wouldn’t put a hole in the bottom of the gorilla plate. Is the v2 still available do you know or is it a case of searching classifieds and ebay? Thanks for the quick-release plate tip BTW,
    Steve
    September 16, 2010 at 10:32 am
    No you’re not screwed. You can screw your tripod into the baseplate, there’s a thread for that (look sideways). I prefer the use of the Manfrotto 394 quick release plates, instead, however. You could screw that on the bottom of the baseplate as well.
    Alternatively, you can buy the glue-on frame from Zacuto and attach the Z-finder that way. It still works, as the frame is identical in size. Available for $5,50 at B&H.
    Branded Channels
    September 16, 2010 at 10:36 am
    I had to buy a Gorilla base plate this Summer, as I had to sent in my 7D for repairs and received a loner from Canon Professional Support (naturally without a glue-on frame). So, from that perspective, it can be nice to keep such a baseplate around.
    Branded Channels
  • Steve Ralston
    September 16, 2010 at 4:53 pm
    Sometimes you can’t see the wood for the trees! Thank you. I think I am going to get a stick on frame though because with my battery grip attached I can’t change batteries without taking the gorilla plate, and therefore my tripod plate, off and then having to put it all back together. This seems a lot of trouble I could do without in the middle of a shoot
    September 16, 2010 at 5:14 pm
    Totally agree with you there.
    I think the guys at Zacuto have to send this one back to the drawing board, as it not very useful, unless you have a loner without a frame glued to the back…
    At IBC in Amsterdam, I saw a viewfinder that allows for angled shoots (works with a mirror), although Zacuto is about to announce an electronic version.
    Branded Channels
