Activity Forums Cinematography Z1 – recently seems to have soft focus problem
  • Z1 – recently seems to have soft focus problem
    Posted by Lucy Moon on June 14, 2011 at 1:45 pm
    Hello hello.
    I’m not a trained cinematographer but I film docs with a Z1. Most recently I’ve got a feeling something is off with the ‘push to focus’ facility. I mostly keep it on manual and push to focus before recording (in interviews for example) or when reframing. The distance readings it give me seem to vary a bit too much from one push to the next.
    Also, on inspection of captured footage, it always seems a bit out and soft.
    So I thought of asking
    – is there anything in the mechanics of the distance-detection that needs re-calibrating/servicing? (dust in the camera??)
    – Is there a way (with a yardstick/meter ruler) to test the autofocus to find out for sure?
    – perhaps this this normal and should I just use the ‘expanded preview’ facility to focus manually by eye?
    What think you?
    Cheers!
    –Astrid.
    Lucy Moon replied 15 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
