Activity Forums Adobe After Effects Expressions Z-space expression over expression?
  • Z-space expression over expression?
    Posted by Eliezer Cisner on January 21, 2014 at 3:53 am
    I don’t know how to put this, I’ll try my best.
    I’m trying to make a Z-space-fly-through and I’ve distributed all layers in z-space by adding the following expression:
    t = thisComp.layer("Null 3").effect("Slider Control")("Slider")
    i = index*t;
    [value [0], value [1], i]
    So far so good, but I’d like to add an additional fly-in to each layer by itself for a couple of frames. So instead of just a general fly-through, each layer should have a bit of a z-position animation on its own.
    Question is, how do I add that additional z-position animation to the layers, since they already have the general distribute expression to it?
    Hope I’m clear enough.
    Eliezer Cisner replied 12 years, 8 months ago 3 Members · 4 Replies
  • Jeff Bobbington
    January 21, 2014 at 3:30 pm
    Apply it to the anchor point instead of the position?
  • Eliezer Cisner
    January 21, 2014 at 3:34 pm
    Deadline’s looming, so I ultimately converted the original position expressions to keyframe, of which freed me up to add manual additional keyframes.
    Regarding your reply, I haven’t thought of that, good thinking!
  • Darby Edelen
    January 22, 2014 at 9:00 am
    [Eliezer Cisner]
    t = thisComp.layer(“Null 3”).effect(“Slider Control”)(“Slider”);
    i = index*t;
    [value [0], value [1], i];”
    How about this?
    t = thisComp.layer("Null 3").effect("Slider Control")("Slider");
    i = index*t;
    value + [0, 0, i];
    You can then animate the position property with keyframes. When your keyframe has a Z value of 0 that will correspond to the distributed position defined by the ‘i’ variable.
    Darby Edelen
  • Eliezer Cisner
    January 22, 2014 at 2:02 pm
    Thanks for your help, Darby.
    As I said, since I converted the expressions to keyframes, I (unfortunately) no longer have this issue at the moment, but this can sure help me in similar situations. Thank you for your time.
