Activity › Forums › Adobe After Effects › z rotation, circle becomes oval
  • z rotation, circle becomes oval
    Posted by Azlanf on September 15, 2006 at 5:52 am
    The problem,
    if i set a layer of (for example a round perfect circle) to 3d and rotate on the z plane axis, the perfect circle becomes oval at certain degrees of rotation and i want it to maintain shape…how? it happens also on other shapes.
    Azlanf replied 20 years ago 2 Members · 2 Replies
  • Steve Roberts
    September 15, 2006 at 5:17 pm
    If you’re working in non-square pixels (say, DV), consider turning on Pixel Aspect Ratio Correction. Check the help.
  • Azlanf
    September 16, 2006 at 12:39 am
    Thanks guys, ill try that…
