Activity › Forums › Adobe After Effects › Z-positioning problems
  • Z-positioning problems
    Posted by Jonathan Mack on January 22, 2009 at 11:29 pm
    I’m having a problem with the Z-positioning bouncing in between two key frames that apparently should be constant without an easy-ease, bezier, or continuous bezier, but it fails by bouncing back a few in Z-space when I didn’t tell it to. This issue also appears when using a camera in Z-space too.
    Does anyone what is going on here?
    Jonathan Mack
    Motion Graphic Designer
    Christ’s Church at Mason, Ohio
    Jonathan Mack replied 17 years, 8 months ago 2 Members · 2 Replies
  • Curious Turtle
    January 23, 2009 at 8:33 am
    Select your keyframes, right-click on one and choose Keyframe Interpolation. If you want your keyframes to be linear then set both parameters to linear there.
    HTH,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Jonathan Mack
    January 27, 2009 at 6:27 pm
    Thanks, I should have noticed this.
    Jonathan Mack
