Activity › Forums › Boris FX › Z Positioning for reveal animation
  • Z Positioning for reveal animation
    Posted by Michael Mills on June 5, 2009 at 6:45 pm
    I have an EPS file I am revealing using a paint layer inside the mask. So the EPS layer is drawing itself on the screen. Is there anyway to manipulate the Z positioning, so as it draws on the screen it moves away from the viewer toward the main logo? I’ve tried using a container without success.
    Peter Mcauley replied 17 years, 3 months ago 2 Members · 1 Reply
  • Peter Mcauley
    June 5, 2009 at 8:05 pm
    Well if you were using text you could achieve this effect with a title container, however you’re using an EPS file and as far as I know there is no easy way to accomplish the look that you have in mind.
    You could try using several instances of the EPS file and then push each instance back in Z space as it completes the reveal … that might do the trick.
    If I can think of another tip for producing this effect I’ll let you know.
    Cheers,
    Peter.
