Activity Forums Adobe After Effects Z-Buffer combine
  • Z-Buffer combine
    Posted by Daniel Keetman on December 17, 2007 at 9:10 am
    hello outthere,
    does anybody know a way to use the Z-buffer channel in After Effects for compositing (z-blur, etc) if the file exists as a seperate 8bit picture (tif). I need a function like Channel-Boolean in Fusion. The Problem comes from Cinema 4d, that not aible to render rla/rpf files with integrated z-buffer through net-rendering.
    Any ideas?
    thanks in advance
    daniel
    Gerd Guegel replied 18 years, 7 months ago 3 Members · 2 Replies
  • Darby Edelen
    December 17, 2007 at 6:11 pm
    If you can render a separate file with depth information from your 3D package then you should be good to go… I’ve even seen people fake the depth information by adding a black fog to their scene and rendering with all white materials.
    You can use this render in a similar fashion as the 3D Channel effects, although it is limited to only depth information (no id, material, or other info). For example, you could use it with a Lens Blur effect to get a depth of field look.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Gerd Guegel
    February 8, 2008 at 10:51 am
    I have the same problem.
    A workaround for some of the cases is to use the depth image as a luma matte and adjust depth with color correction (curves, levels, aso) on the depth image layer.
    But for the “real cool stuff” like z comps it doesn’t work…
    hopefully someone out there has a solution…combining a grayscale into the z-aux-channel in afx …or even better render z info integrated on net render….
