Activity Forums Maxon Cinema 4D Z-axis explanation
  • Z-axis explanation
    Posted by Josh Dekay on April 12, 2014 at 9:00 pm
    Hello, I’m a new user of C4D and hope this is the correct place to ask a couple fundamental questions.
    I am a bit confused with the orientation of Z-Axis. It appears that Positive Z moves away from the “front” of the scene. This is confusing to me as it feels more logically (in my mind) that Positive Z would move closer to me when looking at the scene.
    I’ve also read that all models should face in the direction of Positive Z, which is strange knowing that the default setup of a scene in C4D essentially “encourages” this to be build in an opposite manner due to the default view which a new project starts with.
    Is the Positive Z Axis pointing forward or backwards?
    Is it standard/a good idea to build a model facing in the direction of Positive Z?
    Thank you for your time.
    Josh Dekay replied 12 years, 5 months ago 2 Members · 3 Replies
  • Josh Dekay
    April 14, 2014 at 8:20 pm
    Does anyone have any insight they can offer on these two questions?
    Thank you.
  • Brian Jones
    April 14, 2014 at 9:14 pm
    if you are the camera then positive movement into the space you are looking at, is away from you. That’s just a way to look at it, they had to make a choice somewhere. Positive Z is definitely into the screen in the Front view, in the perspective view it just depends on where your camera is. The way each of the axis XYZ arrows points is in the positive direction (in whatever space you are in, Local or World)
    Others may have better examples but I think it’s not as important as it was to orient in the Z, it still is at times – the Align To Spline tag needs Z alignment, there are more examples that are not coming to mind at the moment – and there are newer tools like the Spline Wrap deformer where you can choose the axis…
  • Josh Dekay
    April 15, 2014 at 7:23 pm
    Got it – thanks for your input BJ!
