Activity › Forums › Blackmagic Design › yuv monitor?
  • yuv monitor?
    Posted by Simon Brewster on December 20, 2005 at 4:04 am
    i am using a decklink sp and a sony pvm 20m4u monitor in component yuv mode…but i have a pattern all over my picture…can i monitor this way? or i have got something wrong
    also i believe on a mac you can down rez to your monitor but not on pc why is this?
    thanks
    Trevor Kinsey replied 20 years, 9 months ago 2 Members · 1 Reply
  • Trevor Kinsey
    December 20, 2005 at 11:54 pm
    Are you sending YUV or composite to the monitor. If you send composite signal down the Y to a component monitor it has moire like pattern over the picture. Check that the Decklink card is set to output component signal, or use a composite input on the monitor.
    Trevor Kinsey,
    Technical Producer,
    CVP Film and Television,
    Melbourne,
    Australia
