Activity Forums Panasonic Cameras Yucky interlacing – 24p project
  • Yucky interlacing – 24p project
    Posted by Bintfilm on September 10, 2006 at 5:08 am
    I have bad interlacing and jumpy effects that’s created when things are obviously not done right with 24p, digitizing and timelines. I have read posts and I have tried most all the advice and I still have the same problem. The one thing I cannot do is redigitize my footage as I am on a major deadline.
    Here’s the info if you can help:
    Background:
    Shot on Panasonic DVX100a – 24p
    All clips are 24 w/the exception of a handful that are 29.97 (Mistake, I know.)
    Have both a computer monitor and tv monitor for playback
    Solutions attempted:
    I had originally been editing on a 29.97 timeline so what I did were copy and paste my edits into the following sequences:
    23.98
    23.98 with 24 Timecode
    29.97 with used “progressive” in Quicktime advanced settings
    Problem:
    They all look the same with the yuckville interlacing and jumpiness.
    Thanks bigtime to anyone who can help. I’m in a bind/crunch and it’s urgent.
    Nicole
    Fernando Acevedo replied 19 years, 11 months ago 3 Members · 4 Replies
  • Noah Kadner
    September 10, 2006 at 6:10 pm
    What is your capture frame-rate? It must *always* be 29.97 and then remove advance pulldown.
    Noah
  • Bintfilm
    September 10, 2006 at 6:23 pm
    The video frame rate in my project says the clips are 24. An asst editor digitized about 2 years ago and I”m not sure of the capture rate.
    Nicole
  • Noah Kadner
    September 10, 2006 at 11:24 pm
    Without knowing the capture frame rate there is little you can do. Chances are he made the common mistake of setting the capture frame rate at 24 resulting in clips with incorrect interlaced frames. Only way to fix is to go back to original media.
    Noah
  • Fernando Acevedo
    September 26, 2006 at 4:35 am
    Hi Noah:
    Why if the DVX 100A is a digital format source & camera did Nicole have to “digitize” from an already digital format? Or is she talking about “capturing”?
    HASTA LA BYE BYE!
