Activity Forums Apple Final Cut Pro Legacy Youtube HD keeps going wrong for me
  • Youtube HD keeps going wrong for me
    Posted by Tom Rowley on February 3, 2009 at 10:12 pm
    I’m trying to configure the proper settings to export a file to youtube HD. It was shot on HVX 201, in Dvcpro HD 1080 50i.
    I’m exporting through compressor – H.264, keyframe every 20 frames, 3000 kbps, 44.1 audio rate. No matter what I do the image turns out very fuzzy in ‘normal version’ but clear in ‘watch in HD’.
    https://ie.youtube.com/watch?v=8hvs7Y_kVfo
    Is this normal? I managed to decrease the stutter by using uncompressed 8 bit sequence setting in fcp and a auto keyframe in compressor.
    I looked around and saw other HD uploads that looked great in regular quality.
    Hope someone can help,
    Tom
    Tom Rowley
    Freelance cameraman
    http://www.tomrowley.com
    Adam Zay replied 16 years, 9 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    February 3, 2009 at 11:08 pm
    You aren’t deinterlacing. Your ‘Watch in HD’ version is badly interlaced, then youtube’s servers are reencoding that and probably not doing a very good job. You need to start with a high qualty deinterlaced (ie progressive) file, then send that to the tube which should then get transcoded a bit better, but that part is up to them and not you.
    Jeremy
  • Tom Rowley
    February 3, 2009 at 11:15 pm
    Cheers for advice, but actually tried a good few variations where I de-interlaced (trying both regular de-interlace and tmts smart de-interlace) and these too were poor quality and showed similar problems.
    https://ie.youtube.com/watch?v=Bi5ApwZhrto
    But will give de-interlacing another go if you reckon it might be the answer
    Tom Rowley
    Freelance cameraman
  • Jeremy Garchow
    February 3, 2009 at 11:23 pm
    That one looks like normal YouTube video to me, and the HD option looks much much better.
    When Youtube recompresses it, there’s nothing that you can do to control it’s quality, it seems. It just simply reccompresses your already compressed HD version. If you want a really good looking SD version, you should upload that separately, but youtube was never known for it’s quality.
    Jeremy
  • Adam Zay
    December 24, 2009 at 6:38 am
    hey tom, did you figure out beter settings, im having the same problem…. im shooting with a hpx170
