Activity Forums VEGAS Pro Youtube and video files
  • Youtube and video files
    Posted by Darren Campbell on July 5, 2010 at 8:11 am
    I’ve tried like 6 times trying to upload this video to Youtube but once it reaches 100%, I get an error telling me that it’s unable to convert video file.
    I used MediaInfo to reveal everything in the file.
    General
    Complete name : C:\WarcraftMovies\SephistoFrostFire1-muxed.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 713 MiB
    Duration : 7mn 48s
    Overall bit rate : 12.8 Mbps
    Encoded date : UTC 2010-07-03 20:13:42
    Tagged date : UTC 2010-07-03 20:13:42
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 7mn 48s
    Bit rate mode : Variable
    Bit rate : 12.5 Mbps
    Maximum bit rate : 46.4 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 30.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.201
    Stream size : 699 MiB (98%)
    Writing library : x264 core 100 r1659 57b2e56
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=12500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Encoded date : UTC 2010-07-03 18:49:46
    Tagged date : UTC 2010-07-03 20:14:47
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 7mn 48s
    Bit rate : 254 Kbps
    Maximum bit rate : 323 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 44.1 KHz
    Stream size : 14.2 MiB (2%)
    Encoded date : UTC 2010-07-03 20:14:46
    I render the project in Sony Vegas Pro 9 using uncompressed Lagarith Lossless Codec, then I compress the file in Megui using an MP4 Container etc.
    It plays just fine in VLC Player. So what is wrong??
    John Rofrano replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    July 5, 2010 at 1:21 pm
    …then I compress the file in Megui using an MP4 Container etc. So what is wrong??
    You should be asking this on the Megui forums since Vegas had nothing to do with this. Why would you buy an expensive program like Vegas Pro with high quality codecs and then use a free open source utility to render your videos?
    Personally, I would forget about Megui and use the Sony AVC render type in Vegas with the Internet 16:9 HD 30p template that Vegas Pro 9.0 provides for YouTube. This is what I use for my YouTube videos and they work fine and look great.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
