Activity Forums DaVinci Resolve “Your GPU Memory is Full”, but Resolve continues to render
  • “Your GPU Memory is Full”, but Resolve continues to render
    Posted by Duke Sweden on September 27, 2017 at 2:28 pm
    I expected to get that error message since I was doing an experiment with Neat Video on 4 clips and timeline set to 4096×2160 DCI. I don’t know if someone will answer this before the render is complete (55 minutes left), but is Resolve actually rendering or will I get an error message at the end saying render could not complete, or words to that effect?
    Kind of odd that I don’t have enough VRAM yet Resolve continues to render.
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    Premiere Pro CC 2017 v.11.0
    Duke Sweden replied 8 years, 10 months ago 5 Members · 9 Replies
  • 9 Replies
  • Joseph Owens
    September 27, 2017 at 2:49 pm
    [Duke Sweden] “Kind of odd that I don’t have enough VRAM
    GeForce GTX 1050ti”
    As if there weren’t enough mysteries. Although it is important, your onboard RAM is not that significant; it is the GPU VRAM statistic – in your case, 4GB – that is causing this warning. Stacking up several frames of 4096 on a single 1050Ti is going to exhaust that resource very quickly, and that is what is happening if you are adding a third-party OFX plugin.
    Your render probably won’t crash, but the frame rate is obviously in the dumpster.
    jPo, CSI
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Duke Sweden
    September 27, 2017 at 2:51 pm
    Joe, I already knew about the lack of VRAM. My question was, will I have a successful render when it’s done, since it’s still rendering. I’ve only got 1:44 left to find out.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Duke Sweden
    September 27, 2017 at 3:17 pm
    UPDATE: Clip rendered perfectly, no dropped frames. Take THAT, “GPU Memory is full” error message!
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Ole Kristiansen
    September 27, 2017 at 3:18 pm
    If anyone can answer this – I would like to ask about the winning numbers in the lottery !
  • Duke Sweden
    September 28, 2017 at 12:24 pm
    If I were you I’d pick a more popular thread to ask that question 😉
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Dmitry Kuznetsov
    October 27, 2017 at 8:07 pm
    I had the same error messages then used this plugin. But I had some frames rendered with artifacts. So be careful.
    Color Grading Specialist / DI Colorist / DaVinci Resolve Colorist
    For business inquiries:
    https://contact.photodmitry.com
  • Duke Sweden
    October 28, 2017 at 3:45 am
    I actually created a VBScript that clears my RAM cache without having to reboot. Just right click and “open in command prompt”. Happens instantly and it frees up all my RAM. I then do my render which so far has gone off without a problem, even when tested with heavy tweaks. And I do mean heavy.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Glenn Sakatch
    October 28, 2017 at 3:14 pm
    I’ve had it happen both ways…renders that worked, and renders that were all glitchy, so just double check.
    Glenn
  • Duke Sweden
    October 29, 2017 at 11:35 am
    Thanks, Glen. I always do. Again, I’m just a hobbyist, I don’t have clients waiting on me, and my videos are usually no more than 4 or 5 minutes long. Easy to check for glitches and stuff. Cheers!
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
