Your freind till the end! Once again! Need more advice guys!
Adam Harrington replied 9 years, 12 months ago 5 Members · 12 Replies
John Rofrano
September 11, 2016 at 7:32 pmActually all he needs to do is what Graham has already suggested but he didn’t understand. Change the row type from Header to 2 Column and you’re done. No need for any other tools. Adam was using the header type to make two column text which is impossible to line up. Use the appropriate row type and everything will line up as expected. It was clearly shown in the video that Graham linked. You can even paste from a WordPad document. Just use a TAB between the columns and Vegas Pro will line them up for you.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
