You may be using a compression type without the corresponding hardware card
I’m trying to export a documentary, which has SD/HD/stills etc etc, to a solid ProRes which I’ll then use a cut list on..
However, I cant export the movie because of this error, “you may be using a compression type without the corresponding hardware card”
There are hundreds of photos.. supposedly if they are not RGB it can cause this… going through each photo sounds nightmarish.. any fixes?
