Activity Forums Adobe Premiere Pro Yikes! Cineform for HDV Premiere CS3 project?
  • Yikes! Cineform for HDV Premiere CS3 project?
    Posted by Errol Wright on November 21, 2008 at 10:05 pm
    Hi there,
    I am in the process of getting ready to edit a documentary project in Premiere CS3.
    I imagine the project will be about 90mins in duration and will probably be capturing about 10-15 hours of footage after logging and a paper edit.
    I have material shot on many formats incl DV,DVcam and HDV and have been most recently been shooting HDV on a Sony Z1. I will be shooting many formal IVs in the next couple of months before the edit.
    In my down time I have been looking around the web and to my horror have read about the difficulties of HDV editing, and want to know if this is still a problem and will I need to use Cineform Aspect?
    My main concern is that I don’t want to get half way down the track and have my computer slooooow down. I’ve been there before (on an old system) and its unmerciful! Or would I be better just to down convert from HDV to DV and edit as a DV project? In which case should I shoot my interviews in DVcam…
    Any advice would be really appreciated.
    DELL PRECISION T3400 / XP PRO SP2
    INTEL CORE 2 DUO 3.0GHZ
    4 GB (4x1GB) 800MHz ECC Dual Channel DDR2 SDRAM
    512MB PCIe x16 nVidia Quadro FX1700
    160GB SATA HDD 10k rpm
    Storage(will probably get 2 x 1TB HDDS Raid 0)
    Jeff Pulera replied 17 years, 9 months ago 2 Members · 1 Reply
  • Jeff Pulera
    November 24, 2008 at 3:31 pm
    Hi Errol,
    I’ve been using the Matrox RT.X2 hardware with CS3 for all realtime performance with HDV and DV. You can capture/edit HDV natively without transcoding or intermediate codecs. Allows you to mix DV and HDV in same project with realtime upconvert/downconvert, and you can connect card to an HD display for full-screen output/preview during the edit.
    Effects require NO rendering! The RT.X2 LE is compatible with your system hardware
    Jeff Pulera
    Digital Vision Productions
