Activity Forums Blackmagic Design yet another quitcktime issue
  • yet another quitcktime issue
    Posted by Viveck on August 31, 2005 at 1:22 pm
    I’m working in 10bit PAL colour space in Premiere. Everything was fine until I used quicktime BM 8bit file. The file plays fine otherwise but whenever I re-render, the rendered portions show very obvious gamma increase.
    Just for test i saved my original file as BM 8bit & 10bit .avi and they both show increased gamma. I also tried new 8bit project and same problem, so I guess it’s not about the bit space it has to be some incompatibility between quicktime/blackmagic/premiere. Does this mean Blackmagic is not compatible with it’s own codec? or is it some sort of conversion issue??
    I would appreciate some quick help, as most of my footage is in quicktime 8bit BM codec (approx 200+ shots) and tweaking every shot is not possible, unless and until i force render everything then reduce gamma then… well too much hassel and it will kill the workflow.
    Thanx for your time in advance.
    vB
    Viveck replied 20 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
