Activity › Forums › Adobe After Effects › Yet another Mac: Ram / Multiprocessing question… Please
  • Yet another Mac: Ram / Multiprocessing question… Please
    Posted by Richard Mamary on April 5, 2008 at 7:29 pm
    MacPro: 2.8ghz dual 4 core; 14gb Ram, (seen in System Profiler); AE CS3 8.0.2
    Everything is fully updated.
    I know this has been asked before, but I am thick, and not the sharpest tool in the shed.
    In AE memory prefs, it says I have only 3gb ram. (Why AE still doesn’t see the RAM, I have no idea…)
    Now, if I set Maximum Memory Usage to 50% = 1.5gb, and
    if I set Maximum RAM Cache Size to 50% = 1.5gb, and
    in Multiprocessing Prefs, I check: Render Multiple Frames Simultaneously, (confirming an additional 7 processors will be used.)
    Then, even though AE “says,” it only saw 3gb Ram total,
    It will still use 8 cores x 1.5gb a piece = 12gb used by AE, leaving me 2gb free for other use?
    Is there anything else I need to do?
    Is there any way to get AE to actually recognize the RAM, or, more importantly, is there any way to confirm it is working?
    I really appreciate the help…
    Darby Edelen replied 18 years, 5 months ago 2 Members · 2 Replies
  • Richard Mamary
    April 5, 2008 at 8:31 pm
    I should have also mentioned I am also running OSX 10.5.2, also fully updated.
  • Darby Edelen
    April 7, 2008 at 5:51 am
    [Richard Mamary] “Now, if I set Maximum Memory Usage to 50% = 1.5gb, and
    if I set Maximum RAM Cache Size to 50% = 1.5gb, and”
    You don’t want to set your Maximum Memory Usage that low, set it to something like 120% (values above 100% correspond to page files/virtual memory stored on your hard drive temporarily).
    [Richard Mamary] “Is there any way to get AE to actually recognize the RAM, or, more importantly, is there any way to confirm it is working?”
    Open up Activity Monitor while doing a render. It’s located in Applications > Utilities > Activity Monitor. There should be several ‘aeselflink’ or ‘aerender’ (i forget what its called exactly) processes running during a render that will each tell you how much RAM their using.
    Your setup sounds correct, aside from the abnormally low Maximum Memory Usage.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
