Activity Forums VEGAS Pro Yet another dumb render question from me…
  • Yet another dumb render question from me…
    Posted by Bob Moyer on January 31, 2014 at 4:39 pm
    Can I burn both a Bluray compliant Mpeg2 file and a compliant Sony AVC file via the SAME DVDA project and on the SAME disc, so that I may watch and compare them to see which is better: i.e. version 1, version 2?
    Bob
    John Rofrano replied 12 years, 6 months ago 4 Members · 12 Replies
  • 12 Replies
  • Bob Moyer
    February 1, 2014 at 3:41 pm
    OK, I managed to find a BD-RE disc and successfully burned the two different renders (Mpeg2 & Sony AVC)in the same DAR project. To my ‘old’ eyes, they both look the same.
    Bob
  • John Rofrano
    February 2, 2014 at 4:43 pm
    [Bob Moyer] “I managed to find a BD-RE disc and successfully burned the two different renders (Mpeg2 & Sony AVC)in the same DAR project. To my ‘old’ eyes, they both look the same.”
    As they should. 25Mbps MPEG2 is about the same quality as 16Mbps AVCHD. The difference is in the file size. You can fit more AVCHD on a Blu-ray than MPEG2 because the files are smaller.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bob Moyer
    February 2, 2014 at 5:35 pm
    Thank you John for your reply. If I may ask you an additional question: this veg file contained some SD clips along with AVCHD clips (majority). It was mentioned in another thread I started that I could modify the Sony AVC render to 26Mbps. When I attempted to render this VegasPro 10 gave an error msg. to the extent that an ‘unknown’ error occurred. Is this due to the SD clips or AVCHD clips that I used or the fact that I combined the two? Hope you can help.
    Bob
  • John Rofrano
    February 3, 2014 at 5:15 pm
    [Bob Moyer] “It was mentioned in another thread I started that I could modify the Sony AVC render to 26Mbps. When I attempted to render this VegasPro 10 gave an error msg. to the extent that an ‘unknown’ error occurred. Is this due to the SD clips or AVCHD clips that I used or the fact that I combined the two? Hope you can help.”
    No, it may be due to you using a very old version of Vegas Pro. Did someone say that the Sony AVC encoder in Vegas Pro 10.0 can create a 26Mbps stream? I’m guessing the limit may have been was increased in later releases.
    ~jr
  • Bob Moyer
    February 3, 2014 at 9:46 pm
    John,
    I am using VegasPro10e and with the “=AVCHD 1920×1080-60i” template, the max bit rate in the drop-down box (custom option) for the Sony AVC/MVC is 16Mbps. However, with the “=Blu-ray 1920×1080-60i” template the drop=down box (custom option) the default is 16Mbps but it offers a selection of up to 26Mbps. This last one is the one I used (tried to use and got the error msg). I finally just used the first template shown above.
    Bob
  • John Rofrano
    February 4, 2014 at 2:54 am
    [Bob Moyer] “I am using VegasPro10e and with the “=AVCHD 1920×1080-60i” template, the max bit rate in the drop-down box (custom option) for the Sony AVC/MVC is 16Mbps. However, with the “=Blu-ray 1920×1080-60i” template the drop=down box (custom option) the default is 16Mbps but it offers a selection of up to 26Mbps. “
    In Vegas Pro 12.0 the Sony AVC Internet 1920×1080-30p template allows for 26Mbps and the AVCHD template goes up to 22Mbps.
    ~jr
  • Thayalan Paramasawam
    February 5, 2014 at 7:47 am
    Hi Sir (Mr.John Rofrano)
    what is differend MainConcept AVC and Sony AVC.Which is better?
    I am always use SONY AVC 16Mbps.But after i done some test on both setting almost same.
    Thank You
    System Details:
    Custom Built
    Working Station 1) – Motherboard – Asus M4A78 Plus,Processor – Amd Phenom llx4 945 Black Edition,Ram – 4GB,Graphic Card – Ati Radeon HD 5990,Dvd Writer – Plextor PX-890SA,Operating system – Window 7 Pro 32 bit and Editing Programe -Sony Vegas Pro 10
    Working Station 2) – Motherboard – Asus M4A88T-V-EVO Series,Processor – Amd Phenom llx4 955 3.2GHZ Black Edition,Ram – 16 GB,Graphic Card – Asus HD 6770 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 11
    Working Station 3) – Motherboard – Asus M5A99X-EVO,Processor – Amd FX 8350 4.0/4.2 GHZ,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12
  • John Rofrano
    February 6, 2014 at 12:33 am
    Yea, they are both about the same. I use Sony AVC for Blu-ray and MainConcept AVC for Internet delivery but you could use either one.
    ~jr
    February 6, 2014 at 5:46 am
    Thank You Sir (Mr.John Rofrano)
    System Details:
    Custom Built
  • John Rofrano
    February 6, 2014 at 11:27 am
    You’re welcome as always. 🙂
    ~jr
