Activity Forums Adobe After Effects Yet Another Credit Roll Question
  • Yet Another Credit Roll Question
    Posted by Martín Domínguez on November 15, 2010 at 5:53 am
    So to the point:
    24 fps
    1920×1080
    Credit file of 8927 vertical pixels
    to be rendered in apple pro res 422
    Thanks in advance.
    PS: My math is a little rusty (and by little I mean a lot), so if it isn’t too much to ask, lets keep the math talk in layman terms.
    Thanks again
    Kevin Camp replied 15 years, 10 months ago 2 Members · 1 Reply
  • Kevin Camp
    November 15, 2010 at 4:49 pm
    i’ll assume that you just want smooth movement….
    there are two easy ways to ensure that you get whole pixel movement (to avoid the ‘wavy’ anti-alias text issue).
    one way is to add this expression to the position property:
    offset=2; //value in pixels per frame
    y=offset*timeToFrames(time-inPoint);
    value-[0,y];
    set the credit layer’s position at it’s inpoint to off-screen bottom (or where ever you want it to start), and it will march up the screen until the end of the comp/layer. adjust the offset variable as needed, but you’ll probably need to keep it less than 5 or 6, or the text will get start getting hard to read…
    another way that is easier for many to work with for timing is to create 2 keyframes for position that are 1 frame apart. set the y value for the second key frame to be the number of pixels per frame movement that you need (say 2 pixels).
    then add this expression:
    loopOut('continue')
    the movement will not happen until time hits the first keyframe, so timing can be adjusted in a more familiar way, then the code just continues that movement. you might add this animation and expression to a null, then parent the credits to the null to make it easy to adjust the credit position separate from the animation.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
