Activity Forums Maxon Cinema 4D Yet another alpha channel question…
  • Yet another alpha channel question…
    Posted by Jakob Steen on January 26, 2010 at 1:42 am
    I have read alot of the posts regarding problems exporting alpha channels and importing them into after effects…
    Right now its very basic… (by the way I am using version 11.5)
    I just have a cube – nothing else – and I want to export it with an alpha channel and put the cube on top of another clip in after effects.
    Here’s what I do exactly!
    Go to render settings – save tab
    Choose quicktime movie
    Choose the ANIMATION compression, and millions of colors +
    Check alpha channel
    Go to “MAKE PREVIEW”
    In options I ensure that the ANIMATION compression and millions of colors + is indeed selected
    Then I hit ok.
    Then it renders out and I place the file into After Effects – and I dont even get to choose how after effects should handle the file. I cannot even go to “interpret footage” and change the settings of the alpha, because its greyed out.
    What am I doing wrong?????
    Is there some secret way of rendering when its alpha or whats code I have to break!
    I am going insane!
    I would appreciate any ideas!
    Thanks in advance
    Tim Shetz replied 16 years, 7 months ago 2 Members · 1 Reply
  • Tim Shetz
    January 26, 2010 at 3:51 am
    There was recently a post about this EXACT thing. I will save you the time of having to look for it:
    Make Preview does not render your project, it makes a preview….so it does not include the alpha.
    You need to render to picture viewer to render it out.
    Hope that helps.
    Tim
