Activity › Forums › Apple Final Cut Pro Legacy › Yes, another monitor question
Annaël Beauchemin replied 20 years, 1 month ago 9 Members · 13 Replies
Daryl K davis
July 22, 2006 at 6:04 pmAnyone have a chance to check out the Panasonic BT-LH2600W?
DK Davis / Editor/ Post Super
Arnie Schlissel
July 22, 2006 at 7:17 pmI’ve seen one at a trade show. The blacks are just as good as on the 17″.
Arnie
Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
https://www.arniepix.com -
Annaël Beauchemin
July 23, 2006 at 12:07 amIf you want to go CRT on a budget there’s the JVC DT-V1910CG for about 3000$. Pretty darn good performance in every aspect, but to get the HD-SDI+ SDI option it’ll cost a bit more… i think the option is like 4000$. You can always work in compenent which will still give you great performance.
https://www.jvcpro.co.uk/item/index_html?item=DT-V1910CG
If you do mostly 24PsF (native 23.98) work, I would go with an LCD screen since all CRT flicker pretty badly at a 48hz refresh rate. Same thing if you work mostly in progessive format. But for interlaced video, CRTs are best and won’t have the deinterlace and interpolation artifacts an LCD monitor will have.
