Y position oscillates between numbers with holds
What I’ve been fiddling with for the last few days is to have the Y position oscillate between 2 values, and then hold for a random period of time. I’ve tried so many variables of oscillation and fiddling with the time factor, but I’m not smart enough to make this work. It would basically help me to create a line like this (attached) using a simple particle emitter.
