Activity Forums Adobe After Effects Expressions y Position move with hold keyframe
  • y Position move with hold keyframe
    Posted by Olly Bea on February 2, 2010 at 1:51 pm
    Hey guys, I had a go at this, but I think its beyond my limited knowledge. There are just too many variable I need to concentrate on!!! Can anyone help?
    1. I have a layer I would like to move up the screen in the y axis (the x does not change)
    2. I would like the layer to move like a “hold” keyframe ie. not continuously, and the amount of time in between each move I can set.
    3. Finally I would like the distance moved would initially be 9 pixels but this would also be adjustable.
    Is this doable or am I being greedy?
    Any help would be superb, otherwise I am going to have a keyframe marathon, and we all know keyframes are frowned upon!!!
    Cheers
    Olly
    Jk Patel replied 9 years, 7 months ago 4 Members · 13 Replies
  • 13 Replies
  • Dan Ebberts
    February 2, 2010 at 2:17 pm
    Try this. Add sliders named “amount” and “delay” to your layer (be sure to set them to something other than zero) and apply this position expression:
    amount = effect(“amount”)(“Slider”);
    delay = effect(“delay”)(“Slider”);
    t = inPoint;
    y = 0;
    while (t < time){ y += amount.valueAtTime(t); t += delay.valueAtTime(t); } value - [0,y]
  • Olly Bea
    February 2, 2010 at 2:26 pm
    Thats amazing, thank you, speedy response as well, much appreciated. You tha man!
    Cheers
    Olly
  • Olly Bea
    February 3, 2010 at 5:49 pm
    Another thought regards this really good expression, if I may…
    Can the delay slider work in frames per second? I am having trouble trying to accurately control it over time when its on a 0 – 100 increment.
    Cheers
    Olly
  • Dan Ebberts
    February 3, 2010 at 5:58 pm
    This should make your delay slider work in frames rather than seconds:
    t = inPoint;
    y = 0;
    while (t < time){ y += amount.valueAtTime(t); t += framesToTime(delay.valueAtTime(t)); } value - [0,y] Dan
  • Olly Bea
    February 3, 2010 at 7:02 pm
    I thought my head might explode trying to work that one out!
    Thank you very much
  • Fernando Almeida
    March 26, 2010 at 3:22 pm
    Hi All, I have similar question?
    I would like to do a stop motion animation.
    My idea is skip frames using Hold keyframes.
    Is it possible to do with expression?
    I would like to apply this expression for rotation and position.
    Regards, Fernando.
  • Dan Ebberts
    March 26, 2010 at 6:01 pm
    I’d start with posterizeTime(). You supply the desired fps. So, if you wanted 12 frames per second, it would be like this:
    posterizeTime(12)
    You’d apply it to each property you wanted to affect.
    Dan
  • Fernando Almeida
    March 26, 2010 at 7:29 pm
    Hi Dan, I try insert your expression in rotation property but a warning massage appear.
    I have 2 key frames start rotation and end rotation.
    When I press Rotation stopwatch with option(alt) a small code appear.
    I remove it and insert your code, but not worked.
    Look the image.
    transform.rotation
    posterizeTime(12)
  • Dan Ebberts
    March 26, 2010 at 7:44 pm
    Ah yes, sorry. Try this:
    posterizeTime(12);
    valueAtTime(time)
    Dan
  • Fernando Almeida
    March 26, 2010 at 8:05 pm
    It works!
    Thank you very much!
    Time is money 😉
    Cheers
