Activity Forums Adobe After Effects XYZ value graph bezier handels?
  • XYZ value graph bezier handels?
    Posted by Ryan Duff on February 15, 2006 at 8:31 pm
    I can use bezier handles when manipulating the speed graph, but not the X, Y, or Z position graphs. I set the key frame interpolation to bezier but no handles show up. I also use Maya so I know the curve animation sysem. So if you had a camera moving in all 3 axis, and you wnat it to ease to a stop in 1 axis how would you do that?
    Mylenium replied 20 years, 7 months ago 3 Members · 2 Replies
  • John Dickinson
    February 16, 2006 at 12:16 am
    The value graph has no handles. There is a work around for accessing the X, Y and Z parameters individually by using the “Separate XYZ Position” animation preset. Type that into the Effects & Presets palette and apply it your layer. It will create 3 Expression Effect sliders that you can adjust individually.
    Hope that helps.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Mylenium
    February 16, 2006 at 6:49 am
    Yeah, thhat’s not possible. As John said, use the workaround with the expressions. There also used to be an experimental feature that could be activated by hacking the prefs file, but it does no longer work.
    Mylenium
    [Pour Myl
