Xvid Mpeg-4 AVI & Vegas Pro 9 – novice
Pete Jefferson replied 15 years, 8 months ago 3 Members · 14 Replies
John Rofrano
January 23, 2011 at 5:29 pmI’m glad that worked and I’m glad I could help. Don’t forget to save that template under a new name so you can use it again (oops… I left that part out). 😉
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Pete Jefferson
January 24, 2011 at 12:24 amActually, while I got you.. Say I import a DVD and I want to create a single video file with it. Say I want it to have the best quality possible with no regard for file size so long as it’s not bigger than the source (if such a thing is even possible). Is there a quick answer for how to render it or do you have to know if it’s HD or blueray?
John Rofrano
January 24, 2011 at 12:56 am[Pete Jefferson] “Say I import a DVD and I want to create a single video file with it. Say I want it to have the best quality possible with no regard for file size so long as it’s not bigger than the source (if such a thing is even possible).”
If you import a DVD it would be Standard Definition (720×480) MPEG2. The highest possible quality is the original MPEG2 file. Any rendering to a lossy codec will produce some loss although you might not see it until after a few generations. The best thing is to keep it in it’s original MPEG2 format and not re-render it. You will not get a lossless render at the same size. Lossless would require a much, much larger file size.
~jr
Pete Jefferson
January 24, 2011 at 1:01 amOkay, I’ll play around with that.
Thanks again John for all your help.
