Activity › Forums › Adobe After Effects Expressions › XSI import/multiple scale issues
  • XSI import/multiple scale issues
    Posted by Bryan on January 23, 2007 at 10:51 pm
    I’m having a multiple scale issue upon importing 3D scene data from XSI into AE. It seems that everything is off by a factor of 1:100 (the world units in XSI were set to feet). When I do nothing to the camera and lights, anything that becomes a child of either light in the scene, needs to then be scaled to %1 to be normal size. Obviously this become a problem when postion keyframes are then applied, and even more of a problem if this object becomes and emitter for trapcode particular.
    I actually have a link to the file, which is posted on my .mac file sharing page. There is also a stuffed version of the file (just in case) and a reference quicktime that is a render of the tail end of the scene for (the 2nd scene light is centered on the model’s waist).
    https://homepage.mac.com/bryan_keeling/FileSharing5.html
    The AE file has the original imported scene comp with the multiple scale issues in it. There is also a second comp were I tried applying expressions to the position of the camera and lights. I just can’t get it to work right.
    If someone could take a look at it and let me know what I’m doing wrong, of if they have any suggestions, that would be awesome.
    Thanks.
    -Bryan
    Uprock70 replied 19 years, 7 months ago 2 Members · 2 Replies
  • Bryan
    January 24, 2007 at 6:34 pm
    Never mind. Someone helped me with it:
    Basically apply this multiplication expression to the postion of the camera and all lights (from mylenium:
    [position[0]*100,position[1]*100,position[2]*100]
    Then apply this expression to the Point Of Interest of the camera (from ats):
    [pointOfInterest[0]*100,pointOfInterest[1]*100,pointOfInterest[2]*100]
    works like a charm.
    This translates feet world units in XSI to pixels in after effects. Meters the factor would be 1000.
    -b
  • Uprock70
    February 4, 2007 at 5:41 pm
    Hello,
    apart from the scaling issue…
    How do i get my XSI camera data imported into after effects?!
    I know it supports maya camera import, but i just can’t get my XSI camera into AE.
    I’ve tried RLA.. but that didn’t work (or maybe i missed out on something!?)
    Cheers
    Barry
