  • Posted by Peter on June 1, 2005 at 8:24 pm
    I am thinking of getting a fcp system using 1TB xserve Raid. Is there a noise issue with the xserve Raid? Can I keep it rack mounted in my edit bay without having a sound issue?
    David Davidson replied 21 years, 3 months ago 9 Members · 18 Replies
  • 18 Replies
  • Francisco Espinosa
    June 1, 2005 at 9:03 pm
    The Xraid is considerably louder than my Medea RTRX SCSI drives. It could be a concern depending on room layout.
  • Sam Zimman
    June 1, 2005 at 9:36 pm
    These work great on noise.
    https://www.xrackpro.com/
  • Peter Wiggins
    June 1, 2005 at 10:15 pm
    Put GBICs on and put it 2K away, doubt if you will here it then.
    Seriously, use glass and move it if noise is a problem.
    Peter
    https://www.peterwiggins.com
    In Paris editing The French Open for ESPN
  • Don Fito
    June 1, 2005 at 10:25 pm
    Mine is loud enough to be a nuisance. I’ll certainly get a soundproof enclosure for it.
  • Graeme Nattress
    June 1, 2005 at 11:25 pm
    It’s a bit louder than a G5, but not as loud as the original Xserves.
    But why a 1TB RAID? I think the Xraid is only worth getting if you max out it’s drives. Otherwise there are cheaper solutions for 1TB of storage.
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • David Davidson
    June 20, 2005 at 11:51 pm
    Graeme
    Which Xraid do you have? How is it for HD?
    david
  • Graeme Nattress
    June 21, 2005 at 12:33 am
    3.5TB. It’s great for HD – I get over 300MB/s read, 200MB/s write configured RAID50. If you get one, just make sure it’s fully populated with drives.
    Graeme
  • David Davidson
    June 21, 2005 at 12:47 am
    Yes, we have several 3.5s too, yet have you found the point where they get full and the write performance drops? I was thinking of striping 2 together to be able to do 4:4:4 outputs.
    Any thoughts?
    david
  • Graeme Nattress
    June 21, 2005 at 12:58 am
    I’ve not filled mine up enough yet!
    Two Fibre cards, and four RAID halves together? That should be more than enough for 4:4:4 capture. I think a single RAID is enough for 4:4:4 playback, and on the verge of being able to capture.
    Graeme
  • Michael Horton
    June 21, 2005 at 1:25 am
    At our big rollout for FCP 5 last May in Hollywood I was working with a Engineer from Apple setting up the system which consisted of a couple XRaids striped together. He was telling me that he found better performance with one rather than striping two. Go figure
    Michael Horton
    lafcpug
    https://www.lafcpug.org
