Activity Forums Media 100 Xserve RAID Setup Issues
  • Xserve RAID Setup Issues
    Posted by Daniel Tuffin on July 21, 2005 at 8:09 am
    Hi, i’m trying to set up an Xserve RAID to work with Media 100 HD. I’m using a 4.4TB (14 Bay) with 512MB cache on each controller, & capturing into M100 at 10-bit HD 1080i. It starts to capture for about 10-20secs & then you can see the activity lights on the Raid drop & M100 reports that recording difficulities have occured, please select a faster drive.
    I’m also using an ATTO 22XH dual fibre card, that has the latest drivers & firmware’s installed from atto’s website. It seems that something is stoping the RAID as it attempts to capture & then loses bandwidth.
    I’ve also tried capturing at standard SD 10-bit & that captures without any problems, it’s only when you capture on full HD 10-bit.
    I’ve gone through the fibre card setup & RAID Admin & all the cache is enabled & the write cache, so now i’m a little lost. I hope that this is easy to fix…..
    Thanks in advance for any help..
    Daniel Tuffin replied 21 years, 1 month ago 3 Members · 5 Replies
  • Floh Peters
    July 21, 2005 at 3:53 pm
    Are you using the latest Firmware and drivers for the ATTO card? And how are your XServe RAID drives initialized? You should create 2 RAID5 sets (one for each channel) across all drives on the channel, and then stripe them together with RAID0 to create a RAID50 set.
  • Daniel Tuffin
    July 21, 2005 at 4:31 pm
    I have downloaded the latest firware & drivers from Atto’s web site & even tried using the older drivers. At the moment the unit is set up as 4 x raid5 slices (2 on each controller). These are then all striped in disk utility to give on 4.4TB. I will look further into the raid set-up. If you have any more advance that would be appreciated.
    thanks
  • Floh Peters
    July 21, 2005 at 4:36 pm
    [Bob Johnson] “At the moment the unit is set up as 4 x raid5 slices (2 on each controller). “
    Why have you done that? I doubt that this is helpful for the performance. How many drives are per RAID5 stripe? 3 with one as hot-spare? Probably this causes your performance problems. If you don
  • Lawrence Marshall
    July 21, 2005 at 11:37 pm
    Floh, you’ve mentioned in the past that you’ve experienced flakiness with arrays set up as one big partition, and that you would recommend two or more smaller partitions rather than one large partition? I’ve got a 5.6 TB Xserve RAID, and that was one of your suggestions when I was having some issues with digitizing…
  • Daniel Tuffin
    July 26, 2005 at 12:14 pm
    Thank you all for your help, the RAID is now working. After many hours of speaking with Apple, they have sent us a updated driver for the raid & everything works like a dream.
    Thanks Again
