Activity › Forums › Apple Final Cut Pro Legacy › XServe RAID copper fibre cable distance
  • XServe RAID copper fibre cable distance
    Posted by Steve Covello on March 17, 2009 at 12:58 am
    Ah, it’s been so long since I’ve been to the Cow…
    Way back in 2003 I had originally installed FCP, AJA KONA and XServe RAID via copper fibre to a G5 (Now a Mac Pro) and was told that the copper fibre limit was 1 meter. Now, the edit rooms have moved around a bit and the 1 meter copper fibre length is a problem. I have found longer cables available online, but I do not know if there would be either a data integrity or data speed problem (or both) if I were to use a 5 meter length:
    https://www.cs-electronics.com/apple-xserve-cables.htm
    Anyone having a problem with >1 meter copper fibre to XServe RAID?
    thx – Steve Covello
    Stuart Simpson replied 17 years, 6 months ago 4 Members · 4 Replies
  • Alan Okey
    March 17, 2009 at 1:01 am
    Why not get some fiber optic transceivers and a fiber optic cable?
  • Aaron Neitz
    March 17, 2009 at 1:05 am
    We tried to do a 5m copper run… and it seemed to work 90% of the time, but then 10% of the time we’d get all sorts of weirdness on that particular station.
    Go fiber optic. it works beautiful. You’ll need a fiber cable with LC/Duplex ends and a pair of SFP transcievers (Finistar makes all that I’ve ever used)
  • Steve Covello
    March 17, 2009 at 1:12 am
    I was hoping to avoid buying new host cards on both ends. I’ll look it up. Any suggestions, or am I confined to just Apple cards?
    Steve
  • Stuart Simpson
    March 17, 2009 at 10:17 am
    You don’t need new host cards – just a fibre optic cable and one of these at each end:
    https://en.wikipedia.org/wiki/SFP_transceiver
    -Simmie
    6 MacPros – Kona 3 & Kona LH
    1 G5s – Kona LH
    xbox360, Wii, PSP, PS3
    https://www.speak.co.uk
