Activity Forums AJA Video Systems Xserve 5.6TB RAID and wonder which raid level
  • Xserve 5.6TB RAID and wonder which raid level
    Posted by Keicol on June 2, 2005 at 6:33 am
    I have a new G5 2.7 with the Xserve 5.6TB RAID, I had it set up at the sales shop for me and I thought I wanted raid 3 but it’s showing only 2.2TB on my desktop, it must be some hugh redundent level, 5 0 maybe, I’d have to look it up in my books, anyway, is it impossible to have a software raid3? I’m using the apple duel channel fiber card. which is the best raid level for HDcam 8 bit that offers some sort of protection and still has speed and lots of space for video? Thanks, Keith
    Steve Covello replied 21 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Peter Wiggins
    June 2, 2005 at 10:23 am
    Out the box & left to cook for 36 hours, you should see 2.2TB either side.
    This will be RAID5. I’d keep it there, but you can reformat it. It is up to you what level of protection you are happy with and how critical your edit job is. RAID50 if you want to combine both sides.
    Peter
    https://www.peterwiggins.com
    In Paris editing The French Open for ESPN
  • Keicol
    June 2, 2005 at 1:34 pm
    It only shows one raid on the desktop, is it 4.4TB then, under disk administrator it shows two 2.2TB drives and one 2.2Raid? Raid 5 is fine, but under the raid tab it shows a raid 3, I thought I couldn’t have raid 3 without a raid 3 hardware controller card? thanks, Keith
  • Steve Covello
    June 2, 2005 at 1:51 pm
    Do this in two steps: First, starting from scratch, create a RAID 5 with one side — “upper” 7 drive units. Then so the same with the “lower” units. Then combine the upper and lower RAID 5’s into a RAID 0. This is RAID 50. It combines the redundnacy protection of RAID 5 on each level, plus the efficiency of RAID 0. Be sure that Journaling is OFF.
    steve covello
    doublewide post
  • Peter Wiggins
    June 2, 2005 at 1:52 pm
    You’ve got both sides plugged in via fibrechannel right?
    Peter
  • Keicol
    June 2, 2005 at 1:55 pm
    yes, both sides are plugged in and are up and on, it must already be a raid 50, I just don’t see anywhere I can retrive that info?
  • Peter Wiggins
    June 2, 2005 at 3:44 pm
    Hard to say why you are not seeing both sides, maybe a duff sfp, fibre or HBA.
    Do you get all the happy lights with the RAID utility?
    Peter
  • Steve Covello
    June 2, 2005 at 5:07 pm
    Here’s Apple’s doc on the subject. It appears that your fully populated RAID comes from the factory with upper and lower preset to their own RAID so that all you need to do is combine upper and lower into an appropriate RAID config for your needs. I am not the world’s expert on this subject, thought my present Xserve setup has been working without a hitch for about 2 years now. So I guess that counts for something…
    https://manuals.info.apple.com/en/FinalCutPro-UncompressedSDEditing.pdf
    steve covello
    doublewide post
