Activity Forums DaVinci Resolve X’s in the timeline ?
  • X’s in the timeline ?
    Posted by Valeria Petit on October 19, 2010 at 10:39 pm
    Hey all,
    I’m doing my first project in Resolve, and I’ve almost sucessfully conformed my timeline ! (I have a couple of unconnected clips, but they’re not important)
    Just out of curiosity: what’s the difference between a blue X and a red X in the timeline ? I couldn’t find the answer in the manual..
    thanks !
    Config : Mac Pro 3,1, 8×2,8 Ghz, 14 Go Ram, Quadro FX4800, Decklink HD Extreme 3D , 8x1TB mini-SAS RAID5, DaVinci Resolve 7.02
    Valeria Petit replied 15 years, 11 months ago 2 Members · 2 Replies
  • Rohit Gupta
    October 20, 2010 at 2:31 am
    When you delete a clip from the media pool, normally it leaves the corresponding entry in the master session so all the grades with that clip don’t get lost. If you have any EDL events conforming to this clip, it will show as Blue Crosses. It tells you that you had a clip earlier which conformed to this event, but it’s been removed from the media pool.
    Now if you add a newer version of that clip with matching timecode extents, it will replace the orphaned clip in the master session, and you will recover all the grades and timeline information automatically. This is quite useful for replacing individual shots with newer versions of the shots from VFX. Of course, you can add both versions, and use the Conflict Resolution window to resolve the conflicts.
    If you want to delete the clip, and also delete the corresponding entry in the master session, there is an option to delete from master session as well.
    A Red Cross means there is no matching clip in the media pool and/or the master session.
    Regards,
    Rohit
  • Valeria Petit
    October 20, 2010 at 5:03 pm
    cool, that clears it up, thanks !
