Activity Forums Maxon Cinema 4D xrefs lose material when made editable
  • xrefs lose material when made editable
    Posted by Seth Olson on May 2, 2014 at 1:05 am
    I have several Xrefs of a single object. I need to render on the farm, so I used Render Elements to collect everything. No Xrefs were copied, so, I tried to merge them instead. But when I merge them, the materials are stripped from the xref.
    Suggestions?
    Seth Olson replied 12 years, 4 months ago 2 Members · 2 Replies
  • Brian Jones
    May 2, 2014 at 3:51 pm
    making the xrefs editable should work (I mean selecting them and making them editable by hand)
  • Seth Olson
    May 2, 2014 at 9:02 pm
    So, I discovered I was corrupting my scene by “updating” instead of “replacing” when changing xref sources.
