Activity Forums Maxon Cinema 4D XPresso type and layout setup
  • XPresso type and layout setup
    Posted by Xavier Shuster on July 3, 2019 at 11:16 am
    I don’t use xpresso often and can’t figure out how to solve this. There is probably some simple solution but I don’t see it.
    I would like to create a setup where I can choose a type and layout of certain objects (example attached). And if I choose for instance type-flat and layout-4 then only this one object should be visible on the scene. Tried already with the compare node but it doesn’t work, at least I can’t make it work.
    Xavier Shuster replied 7 years, 1 month ago 3 Members · 5 Replies
  • Brian Jones
    July 3, 2019 at 4:42 pm
    can you post that scene file?
  • Xavier Shuster
    July 3, 2019 at 5:23 pm
    Thanks for your reply Brian. Here is the scene
    https://www.dropbox.com/s/ujy7bbah1pk9cqg/Scene.c4d?dl=0
  • Brian Jones
    July 4, 2019 at 1:06 am
    this feels kind of brute force-y but for what it’s worth
    13494_boolechoices.c4d.zip
  • Sam Treadway
    July 4, 2019 at 3:25 am
    Here is a simpler setup and expression that takes advantage of the power of cloners.
    13498_drawerselectorrig.c4d.zip
    Explanation:
    In the xPresso tag:
    – The ‘Type’ option triggers visibility of the Cloners which have the Layouts as children.
    – The cloners are setup with ‘Fix Clone’ turned OFF which keeps the clones in their original locations.
    – The cloner ‘Count’ parameter is set to 1 so only one of the children is displayed at a time.
    – The ‘Clones’ parameter of each cloner is set to ‘Iterate’ so that the children will be read sequentially.
    – The Drawer ‘layout’ option drives each cloner’s ‘Offset’ parameter which selects which of the children to display.
  • Xavier Shuster
    July 4, 2019 at 7:21 am
    WOW! Thanks a lot guys! Great solutions!!!!
