Activity › Forums › Maxon Cinema 4D › xpresso to make color pallete Interface
  • xpresso to make color pallete Interface
    Posted by Matthew Geiger on June 17, 2011 at 11:30 pm
    Hello-
    I am making a color palette interface for a scene that we have to map multiple color variations onto.
    Is it possible to have four materials going into a node with userdata to select the one you want to apply, but using multiple choice like radio buttons on a website form?
    Adam Trachtenberg replied 15 years, 3 months ago 3 Members · 2 Replies
  • Brian Jones
    June 18, 2011 at 5:38 am
    xpresso solution. If it’s on a single object the upper part of the xpresso wouldn’t be necessary, if the colors are on multiple objects they need to be in a list to iterate through (which is what that upper part with the Object List feeding into the Tag node is doing). The radio buttons are user data on the xpresso tag.
    2459_radiobuttonsformaterial.c4d.zip
  • Adam Trachtenberg
    June 18, 2011 at 5:32 pm
    I’m sure there’s a more elegant way to do it, but here’s one example: 2460_materialxpresso.c4d.zip
