Activity › Forums › Maxon Cinema 4D › Xpresso Timing Delay
  • Xpresso Timing Delay
    Posted by Jp Pelc on December 12, 2013 at 6:18 pm
    Hey friends,
    I am a long time AE user getting into C4D lite with the new CC upgrade. What I’m creating in C4D is a spinning globe with radio waves pulsating from various places on Earth. Right now I’m copying and pasting my animated radio waves to various parts of the globe, (I just created 2 tubes and keyframed the inner/outer radii) and I’m trying to avoid having to manually go into every set of radio waves and move the keyframes to adjust timing. In AE for 2D layer stacking I use this expression on the position parameter:
    thisComp.layer(index+1).position + [0,0,1]
    That way when I duplicate a file, it just looks at the layer below and adds 1 pixel to the Z position.
    So what I’m wondering is if there is a similar way in C4D to add an expression to the animation, so that when I copy and paste it just looks at the same animation of the layer(s) below and starts moves the keyframes to a few frames later.
    Brian Jones replied 12 years, 9 months ago 2 Members · 3 Replies
  • Brian Jones
    December 13, 2013 at 4:13 am
    it’s probably possible with xpresso but you can’t think of it in AE terms (layers and frames of animation) it’s a different way to work. What are you trying to do, animate a single wave group or trying to offset the different wave groups without having to keyframe them all?
  • Jp Pelc
    December 13, 2013 at 2:24 pm
    I’m trying to offset the different wave groups with no keyframing, or at least with bare minimum
  • Brian Jones
    December 13, 2013 at 4:28 pm
    offset so they don’t all look the same or offset so that they start off small as they start and grow continuously bigger?
