Activity › Forums › Maxon Cinema 4D › Xpresso tag to control object it’s applied to ?
  • Xpresso tag to control object it’s applied to ?
    Posted by Andy Stokes on December 4, 2006 at 3:11 am
    Hi all,
    I’d like to set Xpresso to control scaling of an object to be uniform. By that I mean when I scale X, Y and Z will scale in proportion. I’ve setup some basic xpresso to do this on an object and it works fine.
    However, when I copy this tag to another object I have to re-open the xpresso window and re-link the object to itself otherwise it scales based on the original object.
    Is there a way to force Xpresso to apply the expression to the object which the tag is applied to? This way I can just drop the tag onto any object and not need to re-open the xpresso window.
    Thx,
    Andy
    Sary Alsary replied 16 years, 6 months ago 3 Members · 2 Replies
  • Mylenium
    December 4, 2006 at 4:29 am
    Change the reference mode on the object node to “Use Start Position”. The default “This Object” will do just what you want.
    Mylenium
    [Pour Myl
  • Sary Alsary
    March 22, 2010 at 7:22 pm
    Hi Andy,
    its long time since you post this but i search for solution to do scale proportion in cinema4d and i only found this helpful post without the explanation how or give the xpresso tag.
    kindly if you can simply do, i hope you replay and thanks in advance.
    sary4d
